12.19.2005, 03:19 PM
Captin your almost right in your description. Yes you are locked in 2nd gear. But you dont have to modify the output shaft, you have to modify the INPUT shaft. The directions are included in the kit. You loose almost 2oz of rotating weight, plus the conversion strenghtens your hole tranny, because of the aluminum back plate.
