Thread: pinion slip
MetalMan
MetalMan's Avatar
05.01.2009, 03:47 PM
The cup on the bottom of the set screws typically used on pinions has sharp edges. Over time (tightening and loosening the set screws) these edges can wear out so they no longer "bite" into the motor shaft. A new set screw is often a worthy fix, and threadlock is always a must.
