crazyjr
crazyjr's Avatar
05.06.2009, 05:45 PM
We recommend 1c, but with a good balance charger the packs can take a 2c charge rate uif your in a hurry. Like any battery chemistry, the faster you charge and discharge the packs, the fewer cycles you will ultimately get, but the packs/cells can be charged faster than 1c for sure. I usually charge at about 1.5c.
This is the reason if everyone says get two, i get three, that way i'm covered if i need to hurry. Mike, is the 7800 2s pack same size as the maxamps 8000? I'm more into high volts for my MT and truggy, but i have a T4 setup as a Pro truck and use 8000mah packs. Will the 7800 fit where the 8000 fit?
