starscream
RC-Monster TQ
starscream's Avatar
05.07.2009, 02:45 AM
Originally Posted by littlegiant View Post
Hi, I am thinking of getting a new esc. Can u list the pros of SP escs over the MMM? I am open to all opinions because I don't own any of the escs. Thanks in advance.
If you are looking to use a sensored 4S motor than the SP is a good choice.
Both ESC Prices are comparable
Both ESC PC programming and updates are comparable
MMM Pro's over SP
- MMM Can handle up to 6S Lipo VS SP 4S Lipo max
- MMM has a slightly smaller footprint
- MMM has a 5AMP BEC vs SP 3AMP BEC (this won't be an issue unless you plan to run some major current drawing servo's)
SP Pro's over MMM
- SP runs both sensored & sensorless motors (Sensored in dual mode)
- SP comes with a hand held programmer that you can use anywhere without the need of hauling around a laptop
- SP On/Off switch is FAR superior to the MMM switch. The MMM power switch is notorious for switching off when the vehicle takes a hard hit. This has happened to me numerous times and I finally shoegoo'd my MMM switch to the On position. This obviously isn't a hard selling point but a small notch in the belt for the SP.
Ha Ha
