Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
05.08.2009, 10:11 AM
Looks great Joe! I like the picture step by step conversion video! And that looks like some serious speeds!
Was that on the donated 6s pack? Elite?
Awesome! now make it go faster....
Elite...yep. 5300 30C 6s...they don't have them any more...why I want to see if they'll let me borrow some of their new 5000 35Cs. :)
Cool build and speed video, Joe! As you likely noticed, the stock mechanical brakes on the IGT and IGT2 fade after about 2 passes with the speed you are seeing. I use the Kyosho STR sintered brake setup on mine - waaaay better (they still get smokin hot after a few aggressive stops, but they will lock up all 4 tires and work 10x as well as the inadequate stock brakes). The IGT was even worse(only had one disc vs. the 2 on the IGT2 - neither setup is anywhere near adequate for the kind of stopping power you need. :)
Do you know if the ST-RR uses the same sintered pads??? We used the pads from one of the sets we had left over from all the RCX conversions. LMK! The stock ones were SMOKING HARD after the 2nd aggressive stop...had to try some more...then had NOTHING!!!
Now I hope you realize that the 2650 is not supported on 6s and that you'll invalidate your warranty ;)
But of course. I don't mind paying for it if I break it. ;)
Originally Posted by TexasSP View Post
Very nice Joe. Makes me want to work on my Kyosho Clone conversion.
I am hoping Mike's mount will work on mine as it appears to be an exact clone of the Kyosho. Now if only I could get someone to donate all the parts...........
Go for it man! Something to "complete the fleet" if you don't have anything smokin fast yet. As for the parts donation, I put a lot of hours in for those "donated" parts. ;)
Why aren't motor brakes used in the app instead of mechanical?
It's a 1 way...no way to use the center diff to brake too. :( There are ways but it's just way too difficult and I would suspect prone to problems...don't need the brakes coming on full bore at 140 unexpectedly or not working at all. Reliability is what I'm after.
Joe Ford
Product Specialist
