entjoles
05.09.2009, 11:43 AM
the speed calc. says about 42mph with a 12t pinion , so i would start there and check your temps , i would also look for a 11t if available , or go up on the spur if posible , a 52 , 54 , would help with the gear mesh and give you more pinion options
if you havent checked out the speed calc. it is a stickey in the brushless thread
