Lonewolf039
Lonewolf039's Avatar
05.09.2009, 09:28 PM
Wow I cant believe you where able to fit a motor with 14 and 46 spur and not hit stock drive shaft
howd you do that
small size of motor ?
how you like the gearing/speed ?
I am using a regular 36mm motor with no finns, just the RCM heatsink. It is tight, but fits. If you are going to use a finned motor, you will have to grind the fins a bit to get it to fit. I like this gearing as it is easy on the esc and battery. It's also the perfect speed for my sandpit. If I was doing more open running, I would probably run higher gearing for more speed. It is quick, but not real fast as is.
