05.09.2009, 11:07 PM
Originally Posted by RUSTY XL-5 View Post
Originally Posted by Freezebyte View Post
Brian, I have to ask. WTF is up with the no fan avatar?
Oh no you didn't! Your in for it now.
No no, I'll be gentle (this time ). My personal opinion is that no BL system should need a fan if it is set up right. If it heats up, then you are pushing the system beyond it's specifications. Besides, a fan cures the symptom, not the problem. Not only that, but a fan can (and will) fail, so if you are relying on a fan to maintain good temps, then the system will thermal when it fails.
However, if you are using a fan to supplement a system that runs cool without one, then that's fine. But I still think the benefits are not worth it. The only systems I have that run fans are the ones with a MMM, and that's because the warranty will be void if I remove it. Heck, I even run a couple of Quark 125's perfectly fine (temps ~30-40* above ambient) with no fan, and those are known for running hot.
