05.09.2009, 11:15 PM
Originally Posted by Always Dreamin View Post
a-mazing.
Thanks!
My god- only 38mph with a 1527..... HOW MUCH TORQUE DOES ONE MAN NEED?!!?
I do have a 1521 2.5y but I plan to put that in the 6x6 LST. However that truck may end up being heavier than this truck, so I may swap motors. The 1527 2y is almost the same kv as the 1521 2.5y, so gearing will not change. Not sure if Lutach's LT10 esc will handle the 1527 geared for 35 in the 6x6lst... I guess we will see, 10s at 100 amps at 75% eff is 3.5hp, so I guess it will be fine. Maybe it will work in this truck too... I guess I can give that esc a try, test its limits!
A lot to get that big son of a bitch moving.
It will be long, but I do not plan to run a super heavy wheel tire combo. The cage/roll bar will add some weight, but I will try to design it to be as minimalistic as possible. Lots of large triangles for strength!
