Thread: Brushless MGT
LiqrSicc
LiqrSicc's Avatar
05.11.2009, 07:06 PM
gearing for 55 is why you burned the motor. thats way too fast, 40 is about tops for a monster truck, unless you have a huge motor and like 12s. Smaller tires will help. A medusa 80mm motor might be a good option, 6mm less in diameter than a neu. The kb45 would be even worse. Also, you could change just the input shaft on the tranny to the 4.6 input shaft and run the old style slipper (which i've used for brushless and has worked)
otherwise, a cd would be awesome and open up gearing options
a CD is what I'm looking for. I need the gearing options and the stock tranny wont let me do it. The slipperential on a custom mount... I better ask Mike.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
  Send a message via AIM to LiqrSicc
