SpeedAssault
SpeedAssault's Avatar
05.12.2009, 12:05 PM
First pic
I cut the stub axles to fit the Losi side diff gears and still use Revo axle shafts
I replace the stub wheel axle with new titanium stubs.
To make Lockers for the diff and the new Losi muggy center Diff I cut a piece of aluminum and Delrin to fit inside the carriers which ties the left/right outputs to the ring gear
(note: I used Delrin because it was easier to cut and sand down in the belt sander and it was lighter by a tad.
using the Alum one for the Center
ID:	6975   Click image for larger version
ID:	6976   Click image for larger version
