Originally Posted by Semi Pro
cool, looks like i nice motor for $110
how does the power compaire to the kb45?
Honestly, I can't say. The KB-45 was on 6s 7400mah and had a kv of 1200, through a MMM. Now this Feigao is on 10s 3700mah with a HV-110. No real comparison there, unfortunately. Not to mention the buggy is set up differently than before. So the best I can say is "comparable".
Originally Posted by What's_nitro?
3) Did it happen while you were working on R/C stuff?
No, it happened about 2 1/2 years before I got my first RC car.
Originally Posted by sikeston34m
The scar on your left thumb was caused by:
While you were using either a Drill press or a mill machine, the part you were drilling/machining came loose from it's vice or your grip. While rotating out of control, it contacted your flesh, ripping and tearing like a big dog.
Note to self: always use a vice to secure work.
Anywhere close?
How's the performance of this new motor?
Nah, that's where the scar on my left middle finger came from
http://img.photobucket.com/albums/v1...r/IMG_0457.jpg (click if you dare) (note the white band was due to intense moisture from keeping a bandage on it all the time)
Performance was great! Just gotta work on dialing in the ESC settings and pinion size.
