Joey
The Big Cheese
Joey's Avatar
05.13.2009, 02:35 AM
Thanks, it is just long enough to get an average lipo pack in front of the tranny!
Decent tools are a must, the band saw was only 100 bucks... And blades last a while if you keep them tensioned correctly. Good hand files are also a must have tool, I use the best I can find...
It definitely shows, as was said before those cuts look waterjetted. Is it easy to turn the aluminum as you are cutting with the bandsaw, or is it like a hacksaw where you can pretty much only make straight cuts?
For this purpose, does a band saw work better than a mill?
