05.13.2009, 11:51 AM
The black endbells and black wires lead me to think it is a hacker motor as well. Can you measure it for me? The length of the can w/o the shaft, and the diameter of the can too. Looks like it has an 1/8 shaft...
The heatsink looks to be one of the slide on units that was cut to fit the motor when it was mounted close to the chassis or some other flat object. It might be glued on as well, with some thermal epoxy.
