mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
05.15.2009, 09:45 AM
ZERO SLOP 17 MM OFNA ADAPTERS
The Ofna adapters are tough and cheap. The Traxxas adapters are very similar except for the splines. Both of them have slop that gets worse with time because they get grinded by the threads of the stub axles. There are other systems out there that require the use of 8 mm stub axles or stub axles with no threads but they end up being expensive, although they are very good. Also there are cheaper styles that work great but I started with Ofna before any other systems came out and with the modifications I did, they have been working so well that I don’t see why I should change anything.
GETTING RID OF THE SLOP
No brain, no headaches.
