brushlessboy16
brushlessboy16's Avatar
05.15.2009, 10:34 AM
hmmm My freind has a hyper7 buggy with the 2650 in it.... 6s would make it AMazing.
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 20
Total Voltage: 22.2
Motor KV: 2750
Tire Diameter (inches): 4.6
Tire Ballooning (inches): .2
Motor Current Draw: 50
Motor coil Ω: 0.0035
Spur/Pinion Ratio: 2.3 : 1
Total Ratio: 7.60769 : 1
Tire Circumference (inches): 15.71 inches (398.98 mm)
Total Motor Speed: 60568.75 RPM
Vehicle Speed: 118.43 mph (190.23 km/h)
Effective KV Value: 2728.32
KT constant: 0.49 oz-in/A
Motor Torque: 0.13 ft-lbs
Final Torque: 0.97 ft-lbs
Final Power: 1110 watts (1.5 HP)
