Can a BL motor be run in reverse-rotation without any loss in power or efficiency?
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
Question Can a BL motor be run in reverse-rotation without any loss in power or efficiency? - 05.16.2009, 03:51 PM
Like the title asks, can a brushless motor be run in reverse-rotation without any loss in power or efficiency?
The reason I ask is because I am building a brushless 1/8 GS Racing Storm buggy, and I would like to move the RCM motor-mount from the right-rear to the left-front, because I have a layout in mind that would be perfect if I can put the motor in that spot...the only problem is, with the motor in that location, it will spin the drive-train backward. But if I can run the motor in reverse-rotation everything will be perfect!
Thanks in advance for any help you guys can provide, it will be much appreciated!
-Chad
PM ME IF YOU HAVE THE BELOW:
