Frozen72
05.17.2009, 04:54 PM
I'm proud to say that I'm 99% done with my RC18T FT Build. I have everything in hand minus the eZRun Motor and HC Deans Plugs. They should both be here by Friday. I'm going to test it out for a few days before I send my Mamba to MTM to have the signal wires resoldered.
All of the upgrades so far are:
RPM Bumper
DP Gear Cover
DP DragLink
FT Shocks with O-Ring Mod and Green Slime
Pro-Pulse Dirt Tires
Hitec HS-65HB
Tightened Servo Saver
Mamba 25 Pro (Modded Mamba-25)
eZRun 12T 7800kv Motor
Zippy/Rhino 1750mah 2S 25C Li-Po
Other things I bought for the RC18T FT:
IMAX B5 Charger
SwangHobby Volt/Amp Meter
I took some pictures today and it's amazing the difference good lighting will make:
