Finnster
KillaHurtz
Finnster's Avatar
05.17.2009, 09:24 PM
^^^ yeps
Plus you wrote in the stipulation that you want a cool system no matter what. You just aren't going to get it w/ that sized of motor w/ that level of power demand (maybe if you went to a high voltage setup, but not on what you got now.)
I don't see how just switching one brand of motor for another is really going to get you anything. Neus are arguably the best motors on the market. Ditching it for a Tekin that is 200kv lower isn't going to do much for you.
If you really want that much power, need a bigger motor to play safely. Someone here has a 1521/ 1Y (1600 kv) for sale. I would just get this. Tone down the insane rpms, and use the greater TQ to pull the gear, esp w. the gear limited Muggy. A 1521 on 6S, that bitch will be fast. Not sure your batts are up to it, but thats another story.
Personally I would just do this first, and not waste my $$ swapping around escs and all that. I'd save the money for bigger batts down the line. The controller should be fine. Else drop to 5S like Mike said and be happy w/ what you've got.
