Thread: RX8 Race Report
BUSAFIED
05.19.2009, 09:04 PM
Originally Posted by crazyjr View Post
If you're running this in a truggy, you're running the wrong motor. You should be running the 2200kv truggy motor at max, not the 2650 buggy motor. Personally I'd run the 1500-1700 in 4 to 5s before running a 3s setup in a truggy
why is it the wrong motor? Why must it be a 2200kv at max?
When I first started ordering motors for the conversion, I think I was looking at the 2.5D AND the 1.5D. Figured I'd try one first and see how it went, so I cancelled a motor from the shopping cart.
Only to find out after the order shipped that I had cancelled the 2.5D instead of the 1.5D. I spoke to Mike as well and he said that the 1.5D would be fine, but just to be aware that my battery and gearing options would be limited. He also informed me that the 1.5D is an amp-monster.
So far I haven't had any major problems with temps in my set-up. I mean, aside from just this previous race session, my electronics have been happy. Average temps (on an 11T pinion) for everything were as follows:
motor: 126-135 (no fan)
ESC: 130-150 (MMM v3)
batt: 105-125 (3S, 5000mAh, 25C) - the 125 is usually after a rather vicious bashing session
Now bear in mind that most times when we run the ambient temps are usually hovering around 95-96 degrees.
I could be wrong, but I think the set-up is quite happy. For this race session, I moved up to a 14T pinion...which would explain the higher temps.
Am I misguided in thinking that the temps are ok?
