redshift
RC-Monster Square Tube
redshift's Avatar
05.19.2009, 10:00 PM
lincpimp wrote:
"Some have experimented with the various oil additives and have had good results"
I be one of those some, I use STP Oil Treatment.
"I plan to run mine as is with some motor oil (synthetic)"
linc I'd advise against that, unless your trans halves fit together REAL tight... but it's your mess. Also unless you already have synthetic lying around there is no advantage to spending the extra $ over standard oil.
The reason the STP works so well is because it is very viscous, but not draggy. Which means there is no need for a pool at the bottom, just some. Our vehicles get flung around enough so it will disperse evenly. Guaranteed!
