crazyjr
crazyjr's Avatar
12.24.2005, 12:27 AM
It went well. you really need to follow the directions to the letter. One thing though. Put the drive cups on first before you start to assemble and it helps if you have past experience with a revo, but if you follow the directions to the letter you will be ok. One problem though, the G3 battery straps are too wide for the slits in the chassis if you have a grinding bit small enough you could make it wide enough. Not a major problem, but you need to know.
