Thread: Lipo repair
05.21.2009, 10:25 AM
Originally Posted by anson View Post
To pull this thread back on topic. I have a Zippy lipo which I bought a while back and have yet to use, just whacked it on the charger to see what's up and one of the cells is does not look too good.
1.02v
3.81v
3.80v
3.81v
3.81v
It is a 5S 4000mah. Is there a way to resurrect the flat cell? What is the recommended procedure?
Isolate the cell and slowly charge it. Not sure what charger you have, but A carefully watched nimh charger usually works well. Charge at a low rate, like .3amp until the voltage gets up to 3v or so. Then swap back to a lipo charge until it gets to around 3.8v. Then charge the pack as you normally would and balance it at the same time. Let it sit for a day or so and then check the cell voltages. If the bad cell is loosing voltage you may want to trash or reconfig the pack.
