Originally Posted by SnoopMaxx
That shaft will not work
1: The hole in the flat section is only 2mm
2: The flat section is too long
3: The flange in the middle
4: The distance between the holes
They are not like the Traxxas ones
OOPS, I guess it's not as easy to modify. I thought it would need to be grounded to make shorter, drilled, and put in drill press with file to take off the flange. But if the holes are to far apart then it's definitely not worth it.
Thanks for sharing.
cool thing to do is use your axle stubs for this mod and then buy some titanium revo stubs to replace them on the axle.
