05.22.2009, 02:00 PM
Originally Posted by Freezebyte View Post
Ok, WTF is with the serious off topicness all of a sudden.
Dude, the thread got pointless, too many people saying stuff and no actual info.
So I just weighed some stuff. All in grams.
Big Joe tire w/ foam 294.30
Proline 40 series beadlock (commando?) 173.50
Both of the above on the scale at the same time 467.80
Stock lst2 atx tire and 420 wheel 432.90
The lst2 tires are taller than the big joes, and look better, IMO. The 420 wheels do have 20mm hexes, but you can put those tires on any 40 series wheel. I plan to run them as is on my lst with 20mm hexes. They will be quite a bit heavier than the maximizer beadlock/ badlands combo I run now.
I also have some 40 series crimefighters on different wheels
40 crimes on losi 420 wheel 294.5
40 crimes on proline wabash spoked wheel 233.80
I guess you can see which I will run on the Muggy... Saving 60+ grams per wheel, 240 grams total, that is quite a bit in rotating mass. I was going to run the 420 wheels as I have 20mm hexes, but I think the weight savings is worth picking up 23mm hexes to match the wabash wheels.
I have some other wheels and tires hanging around, I can weigh and measure them up and post a thread if you guys like...
