George16
Supermaxx
George16's Avatar
05.23.2009, 01:34 AM
Joselito(George) - your tray arrived here today. The tray is an old one(likely a year old or more, as it is the old style tray). I also suspect it was procured 2nd hand by you, as I can't find a purchase record from you for a tray. I assume you have the spacer still attached to the chassis? Our newer trays have the spacer built in - would you like the newer style or the older flat bottom style for a replacement? The inside was also modified slightly on one wall - do you need some extra room on the inside to prevent it from bowing out?
Ian(BL_RVO) - haven't seen your tray yet.
Mike, I bought the battery tray from a forum member last November when I did my ST RR conversion. The spacer is still attached to my chassis . If you don't mind, I'd like to have the newer style. I do need an extra room on the inside. Can you make it 168mm x 48mm instead of the stock 168mm x 45mm?
We are currently out at sea and scheduled to return to port in a couple weeks for about 5 days. I hope to be able to receive it by then because after 5 days in port, we'll be on our way to our deployment and first stop is Perth, Australia for the 4th of July and hoping to be able to run my truck (along with others from the ship) with the locals.
Thank you very much. Let me know via pm if there are any additional charges.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Last edited by George16; 05.23.2009 at 01:38 AM. Reason: Edit-battery dimension change
