rchippie
rchippie's Avatar
12.25.2005, 07:03 PM
not nessicerally, just make sure your locknuts are tight. You also should replace them every so often because the nylon in the nut wears out. If you have room on the axle double nut if you can. This helps prevent the nut from backing off.
REAL MEN RUN BRUSHLESS
