05.25.2009, 03:14 PM
Having the wires soldered on should not be a problem. A local tv repair shop should be able to do that. The puffed cap does worry me... Not sure how easy it is to get the cap swapped out, may require removing the brain board to get to it. I just resoldered switch wires and 1 motor wire on the mm. Not difficult at all, but you need a small tip to do the switch wires, and a larger high powered iron to do the main wires. Might be best to either ship it to castle, or find someone local who can tackle the soldering. You brits must have someone like me hanging around on that side of the pond who could do it for you?
