05.25.2009, 07:08 PM
Originally Posted by A RC Dude View Post
that mite work. what did you use for the straps?
Just some velcro from Lowe's/Home Depot/Menards. This to be exact: http://www.lowes.com/lowes/lkn?actio...340&lpage=none
It has the hooks on one side and the "fuzz" on the other. I just countersink some 3mm screws from the inside of the tray, drill a hole through the velcro, singe the hole edge with a lighter to keep from possibly fraying, and then stick that over the screw along with a washer (to spread out the clamping force) and a lock nut. Pretty simple and works well; I've used that in almost all my setups.
If that won't work, I'm sure it's nothing that a little imagination can't overcome.
