Rebelgium
05.27.2009, 09:40 AM
yes, if you use one of those 4500 21C packs, you'll be able to supply 94,5A continuous. This will be ok of you gear a bit on the conservative side. I've heard 100A continuous is about the minimum for a MMM geared normal.
If you use two of those packs in parallel, you'll get 189A continuous, which is awesome!
the lipo's will never even get warm.
