Well not quite that good, I may change it again.
I forgot to say its now just under an inch longer too, I might treat it to a new body actually.
So electronics in, took ages to cram everything in. Speedo (18.97kwf) is too big so had to trim the middle fin out for the prop to run inside it. If anyone knows of a thin speed controller that can take 18 cells/6S with over 100 amp rating and will run the 4 pole Plettenberg please let me know as the schulze gets hot!
Cut some little grooves int eh diff mount to clamp the wires in place and there we are, added some 500,000 diff oil, cant wait to run it now!
