12.26.2005, 12:10 PM
What I want to make sure of, is whether the controller can tolerate heat and do not thermal with that motor. I also knew that the more volts you use the less amps your setup would drain and that is why I thought it would cause me no problem to try it, however, I hate disappointmant.
Nice to meet you!
