05.27.2009, 08:43 PM
Fp taps on 4s and 5s have 6 wires. They do that as they use the identical plug for both 4 and 5s. The first wire that is red will hook to the same place in the pack as the 2nd red wire, and the main pos lead. Some balancers do not like this extra pos wire, so you may have to delete it. I know that the hyperion 6 series chargers do not mind this when you sue the tp adapter board. Neither will a trakpower/flightpower v balancer.
As far as swapping it over to a hyperion tap, well I would jus buy an adapter, what charger do you have?
