05.28.2009, 04:27 PM
brightened it up with some yellow
Nice that Castle makes the ESC Black and Yellow, weird the motor is green
Motor will look hot with Silver and Yellow
Any body have a proven way of removing anodize other than phosphoric acid/water mixture ?
maybe I'll just use high temp paint
I would take a scuff pad to the motor and get in all of the little grooves. Then spray light coats of yellow until it iss covered. Let it dry in the sun for a day or so and the take some light grit sandpaper and sand the fins till the al shows back thru. That would look really good with the black endcaps.
