05.30.2009, 12:46 PM
the 1527 will be fine with your application, the phoenix hv110 can handle 12s. You will need mechanical brakes with your setup. You might be able to get away with a low kv 1521.
Higher voltage setups prove to be naturally more efficient- so you don really NEED that big of a motor-unless your truck is going to be heavy. Also this allows you to run lighter-lower MAH packs.
A 1521 2.5d Would put you in the ball park...
