05.31.2009, 02:59 PM
Thats what just happened to me yesterday. Traded Revo roller for LST2 roller. Hope to get it by the end of the week.
After seeing the 2200 combo in the improperly set up LST linc was running, I was amazed at both the LST and the 2200 combo. I was sold. I can't wait to try it out!!!
TexasSP: any pics on your lst yet? Curious on the setup.
You should see the muggy run with the 1521 1y and the same badlands that were on the lst, it is crazy. I do need to run taped tires, as the center diff will let the fronts balloon quite a bit. But even when they are 7+" they still do not vibrate much, balancing is definitely a must do!
For 5s in the lst the 2200 is the way to go, I am very impressed with the castle motor!
