scarletboa
scarletboa's Avatar
06.01.2009, 04:47 PM
On the other issue, sounds like the magnet has detached from the shaft- if it isnt broken or cracked, you should be able to glue it back in place with something like jbweld or red locktite.
thank you. the motor still spins smoothly and doesn't heat up really bad, so i'm hoping it is just detached and not broken or cracked.
