06.02.2009, 01:02 AM
Not sure, 50 mph gearing with the 2200 and 6s will be fine with the weight of vehicle you have with the sizr tires you plan to run. I am sure you could gear up to 60 or so without heat issues, although your lipo may get worked harder. Best to start with gearing for mid 40s and check temps. If you feel that is too slow gear up a few mph and then recheck temps... I have tons of pinions so that is my method...
