Byte
06.03.2009, 01:26 PM
There is a pot (the knob) on the end. If you turn that it will turn a servo, or the throttle on the esc. It has a (iirc) 6v or 6s lipo input. You may want to make a rubber band/spring mechanism that returns it to neutral after giving it throttle. That's what I plan to do.
But you can only give full throttle or no throttle at all, right?
