Thread: Pinion Problems
06.03.2009, 09:49 PM
^^ way over complicated. Just use a dremel and a cut off wheel, and put a flat spot on. People are so afraid of grinding their shaft. You won't hurt it. You won't get it too hot grinding on it. It doesn't take much at all. Just a lil flat spot. Then loctite your setscrew. It's that easy. It really is.
