MetalMan
MetalMan's Avatar
12.29.2005, 01:02 AM
Originally posted by BrianG
That brings up a quick question: How are parallel cells, like in 4s2p packs, charged without this same concern? The wires between each cell must be hooked to each parallel set right?
That depends upon construction of the pack. If a pack is built into 4 groups (or blocks) of 2 cells in parallel, then all 4 groups are put into series, then there should not be any concern about charging. Basically, the 2 cells in parallel act as one (1) cell, and always maintain the same voltage between the 2. For this setup, only one balancer would be needed.
Taking 2 series packs and putting them in parallel requires more attention. The cells in one pack cannot balance themselves out with the cells of the other pack. The 2 packs together will maintain the same voltage, but that is different. For 2 packs to be put in parallel during charging, 2 balancers would be needed.
It is always best to get 2 2s2p packs and hook them in series than it is to buy 2 4s1p packs and hook them in parallel. It is much better to charge 2 packs in series than to charge 2 packs in parallel.
Originally posted by Scott711
So the prefered method is a single 5s or 6s pack, right? It seems that would be simpler. What are the dimentions of a pack that size?
The way you have a pack set up depends on the capacity of the cells. If you want 4000mah, and can only use 2000mah cells, then the ideal configuration would be to have a parallel and series pack, as described above.
The dimensions of a pack depend upon the brand and the capacity.
