kalbien
06.04.2009, 07:36 PM
I set my cutoff such that when the pack is depleted and I let it sit for about 10-15 minutes, the voltage rebounds to 3.5-3.6v/cell unloaded. The LVC setting for the same pack can be different depending on what kind/weight/gearing/etc vehicle you run. Obviously, this takes a little trial and error. Start at a safe 3.2v/cell and go up or down from there.
Well this trail could be sort of expensive :) especially error . I will set it higher, 3.3v/cell probably and we will see how it will go. I just blindly (and apparently stupid me) put 4s cutoff there with "tekin knows what they are doing excuse" without much thinking about it :)
well hyperion VX 5s are coming... needed an upgrade
