MetalMan
MetalMan's Avatar
06.04.2009, 09:53 PM
If you want to keep your batteries lasting as long as possible, then raise the LVC even higher. Typically mine is set at 3.3v, even with ~5000mah 20C batteries. You'll have less usable capacity with a higher LVC but which would you rather have: a battery which has a longer life and 1min. less runtime (if that) or a battery with a shorter overall life and that extra bit of runtime?
