PBO
RC-Unobtainium
PBO's Avatar
06.05.2009, 06:02 PM
True... That one guy ha da 7700kv motor on 4s, so I think it should stand up to a few runs up and down the street. Unless he is really lucky and I'm really unlucky I think I'll be ok for a few runs.
Metallover, I'm definately in the speed lovin group
Wander over to isc.com & have a look at Nic Case's thread about setting up for 100mph. He explains a lot of what you're asking
I intend to use a MM/7700 combo I got from linc in my TC5 & will start with 2S & work my way toward 4S. Mods will be required to allow things to fit & I will run 32p (with bore reducer if I have too!!) but there are gear manufacturers outside of RC who I hope will produce 1/8 bore...again lots of links at ISC
The body you use will also determine how your setup handles, I have 3 HPI (2 x 190 & 1 x 200) waiting for trials & I hope the 7733 Stiletto with some vertical stabilizers will work best of the 3...?
