zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.07.2009, 09:09 PM
um, that motor is quite big man, not small. It would destroy a 1512 Neu if given the power.
I run a 1512 Neu and it has all the power I would ever need, it just doesn't run quite as cool as I would like(will hit 160+F when pushed hard). Although, seeing as you can't get a CC 1512 motor, your best bet is a CC/Neu 1515 2200Kv motor.
The 2200 CC/Neu running on that Turnigy 5000mah 5s pack will rock your truck. Expect 2000watts from that setup.
