06.08.2009, 03:32 PM
Hmmmm...I got a response from CC. A Customer Support Rep thinks I burnt it due to my battery not being able to support the draw. Warranty doesn't cover this condition. Although he added I might get a replacement. I've been warned to not used these batts again or it might cause esc to fail. OH man....
IF so, then I wasted roughly $600 bux with the FLightmax 5000 5S 25C's and Turnigy 5000 5S and 6S 25C's.
Can someone chime in if those batts can support my LST with stock two speed and Fiegao 8XL?
One thing i like to mention...in 5S everything was fine. Even shift to second speed. I realized an 8XL might be a little hot in second...so I locked it out but screwing in shift adjustment and. Basically, I have small pinion with big spur...stock gear.
Thanks,
