Rebelgium
06.08.2009, 07:06 PM
Too bad to hear about the CF rod breaking. Indeed it proves the rear body mount flexes a fair amount...
Now you're using a steel pushrod you lost some weight advantage, are you planning to use aluminum later on, or a thicker CF rod?
What was the diameter of the CF rod btw?
