06.08.2009, 11:23 PM
I hit a car tire at 30+ mph. Cracked on part of the upper arm and bent the cvd. Lower front arm and shock were fine,, as were all of the hingepins. I straightened out the cvd and ca-ed a piece of plastic over the crack on the arm. Still going strong. My temps improved after putting 7k fluid in the cd. I guess the unloading of the center diff was causing the motor to run very lightly loaded. I need to either add some cooling holes to the body, or a fan to the MM. I may make a new smaller top deck for the cd and put the MM above the servo so it has more breathing room. Other than that it seems to be a great vehicle. I think it handles better than my crt.5 I had a while back.
