The Cow
The Cow's Avatar
06.11.2009, 11:05 AM
Here is a little extra info from my laymans way of looking at things....
Hope this helps
Heath
I would recommend only playing with front toe first before moving onto rear toe. While camber in effect is your key to optimal traction toe in effect is the key to optimal handling(Very basic overall view but not all inclusive) . Toe is everything when it comes to dialing in your car for turns once you are hooking up! Proper TOE will have a huge effect on ability to control the car when things get hairy…. The more TOE-IN the more stable-planted the veh will feel both front and rear…. When you start to think of separate adjustments just remember front TOE is for corner entry adjustments and rear TOE is for corner exit adjustments. Remember this does cause drag and will cause abnormal tire wear as well on the outer most corners of the tires when TOE-IN and visa versa…. If overly exaggerated this will destroy foams with easy chunking and rubbers by breaking glues seals like butter!
Front TOE-IN will help bump steer, cause a loss of steering feel while improving tracking, and can be used to counteract over steer in corner entry….. Front TOE-OUT will increase bump steer, increase steering feel while deteriorating tracking, and can be used to counteract under steer in corner entry.
Rear TOE-IN will help keep your rear down in bumps, Cause a loss in steering feel while improving tracking, and will help counteract under steer in corner exit….. Rear TOE-OUT will increase rear bounce, increase steering feel and deteriorating tracking, and will help counteract over steer in corner exit…..
"from deep within the barn doors"
** COWRC.COM **
