Metallover
RC-Monster Spudgunner
Metallover's Avatar
06.12.2009, 01:45 AM
They are crimp/welded. Not really welded, but maybe crimped and some heat applied, kind of like resistance welding, no extra material introduced to complete the weld.
Hard to explain, but say you just have 2 cells, open them up so that the cells will lay flat and the tabs are in the middle, firmly grasp the tabs as they come out of the cell on both cells with both hands (one thumb and forefinger on each tab) and pull them apart. You may have to wiggle them a bit, but the little "welds" will pop easily. You may have to go back and forth between the 2 sets of tabs so that you do not tear one set while you are working on the other. Hope that makes sense...
makes lots of sense to me. That one guy said it was impossible... You're really the man!!
